[SOLVED] build error regarding simple uart code
P.Copper
Member level 5
Member level 5
Hi all
I've been trying to test my uart with this simple code below. my problem is that the compiler cant build the code it gives this error
"error: xc.h: No such file or directory".... I'm running the code with MPLAB IDE v8.70 c30 compiler.. and the chip is dspic30f4013. help woul surely be appreciated.
#include <stdio.h>#include <libpic30.h>
#include <p30f4013.h>
#include <uart.h>
#include <xc.h>
// Configuration settings
_FOSC(CSW_FSCM_OFF & FRC_PLL16); // Fosc=16x7.5MHz, Fcy=30MHz
_FWDT(WDT_OFF);                  // Watchdog timer off
_FBORPOR(MCLR_DIS);              // Disable reset pin
int main()
    TRISD = 0; // Set all port D pins as outputs
    // Setup UART - most default options are fine
    U1BRG = 48;            // 38400 baud @ 30 MIPS
    U1MODEbits.UARTEN = 1; // Enable UART
    while(1)
        printf("Hello\r\n"); // Send text via UART
        _LATD0 = 1 - _LATD0; // Toggle LED on RD0
        __delay32(30000000); // 1 second delay
    return 0;
The compiler is looking for a file names xc,h, and can't find it. Verify that that file is sitting in your include directory.
