AbhimanyuSingh
Member level 1
I have to build a buck converter, with variable input from 10 V - !5 V. Use a PI controller to maintain the output at 5 V. I have used SG3524. Now, it is clear that I should be able to attain a pulse width of duty ratio 33% to 50%, exactly speaking. And wider range of duty ratio will be even better. Also I am getting duty ratio of 20% to 70% from SG3524. But the problem comes after that. The output of gate driver IR2117 which is supposed to follow its input, does not follow it for a pulse of duty ratio more than 30%. Why is it so? If i decrease the duty ratio below 30 % the output of IR2117 follows input, but not for more than 30%. There is nothing mentioned so on the datasheet. The frequency i m using is 100 khz. is there any other option for me, like change the gate driver. Can anyone suggest me a gate driver which wont be having this problem. Or else can anyone tell why is this happening.
Ask if have missed some information to provide.
