eem2am
Banned
I need to Provide 700mA to a LED (Cree XR-E).
I have to use a Buck converter as it’s the cheapest way.
The supply rail is pulsating at 100Hz from 27V to 38V.
(it’s the secondary of a mains operated flyback)
The low duty cycle is 3.5V/38V = 0.092
The high duty cycle is 24V/27V = 0.89
Also, I have to dim (by PWM or analog dimming) this current down to 65mA (+/-10%)
At times.
When the LED has 65mA in it, it has a Vf of just 2.8V
-This makes the duty cycle just 0.073
Also, from the same supply rail, I have to charge up two 1.2V Ni-MH batteries.
(200mA charge current)
Again I must use a buck converter.
These have a voltage of 1.8V when discharged.
-So the Buck duty cycle will be 1.8/38 at its minimum. (= 0.047)
Are these duty cycles too low to be realistic with a buck?
Surely the FET on time will be too small when we’re at 300KHz switching frequency.? (around 156ns at worst)
At times.
