Buck Converter Capacitance vs Inductance Value
hassaan1309
Newbie level 5
Newbie level 5
I am designing a Buck Converter as a part of my Final Year Project. Previously its inductance was 820uH and capacitance was 220uF. It was working perfectly. But now I have to change its inductance from 820uH to 1.5mH because I have to use a high current rating inductor for the circuit and it is available only of this value (i.e. 1.5mH). Now when I will install that inductor in my circuit do I need to change my capacitance also to match with it??
Will it be now of a greater value than 220uF or less?
Kindly reply if you know this...
Thanks
Thanks
We should imagine that circuit or this is question for people with 6 sense?
Hi hassaan1309 !
You kidding us ? :-D you simply noticed that you want design inductor and capacitor for a buck converter but what kind of buck converter ? where is the schematic ? what are specifications of your circuit ?
How do you expect that we be able to help you with such a low details ? sorry but we are not oracles ;-)
Ha ha ! hi dear Tpetar i agree with you people with 6 sense must try it :-D
Best Regards
Goldsmith
If you find ripple voltage remains within spec, then you can use the same smoothing capacitor.
As a general rule, the greater the coil's Henry value, the slower your switching frequency, and the greater the ripple, and the greater the capacitor needs to be be.
