berkay_91
Newbie level 5
Hi, I am designing a circuit so that the input voltage normally comes from the battery (3V - 4.2V) and in charging cases it comes from the adapter (9V). Since both power lines come from the same path, I want to use a single regulator. Can you recommend a regulator that works with Buck-Boost and can provide a constant 5V 1A for voltages both below and above 5V?
