Thayne
Member level 3
After soldering together a bridge rectifier to make a 12vdc power supply from a 120/240vac transformer, I was having trouble getting anything to happen once I plugged this in. It turns out the 240/120 switch was in pieces inside its housing. There were tiny ball bearings and springs and a number of paper clip looking pieces of metal. I took apart two other, similar switches, but neither looked the same. Then, tested the transformer with a multi-meter but I get buzzing sound any combination of touching the wires.
My question is... What two input wires should plug into a 120V outlet? Or should I put two wires together on one lead and the other two together on the other lead (if so, which ones)?
Thank you!
T
Thank you!
T
