Broke a slide potentiometer: "Alpha B10K 1H4", where can buy ?
anerDev
Newbie level 3
Newbie level 3
Hi guys,
I broke a slide potentiometer model: Alpha B10K 1H4
I can't found this potentiometer and is a problem !
Anyone can tell me where can I buy this model or a equivalent ?
In attachment the photo.
Thank you.
look for ALPS "S45.." or "RS45..." (where the "45" is for 45mm the travel length)
"B" stands for linear scale (in case of ALPS. other manufacturers use "B" for logarithmic curve. Maybe you can check this.)
"10k" stands for 10kOhms overall resistance.
Klaus
No.
A is for "audio" (Logarithmic). B is linear. All manufacturers are the same.
I'd really like that all are the same.
Klaus
added: also vishay uses "A" for linear. at least in the "P11S, P11A" series..
Hi guys,
I'm searching for "Apls rs45, s45" but there is a problem: the pins aren't the same ! But the measure yes.
In attachment a photo.
