RotateAt60Mph
Newbie level 2
I could use a little layout advice. I'm developing a custom LED display PCB using Fritzing. Lots of LED's with resistors, etc. The board will eventually be mounted in a case with a light-diffusing layer over the diodes themselves.
A separate PCB, which drives the board, provides two 10-pin ribbon cables to the display board above. My problem is that I need to mount the 2 10-pin headers on the bottom 'side' on the PCB (with the LED's being on the 'top' side) because the headers and ribbon cables would conflict with the case.
What's the best practice for bridging one side of the board with the other? Would it be acceptable to just solder (on both PCB sides) small pieces of wire through the PCB?
