Breakdown Voltage of Coaxial Cable
saryee
Member level 2
Member level 2
coax cable breakdown
Hi, everyone,
Does anyone know where I can find any materials on brakdown voltage of coaxial cable?
Thanks!
saryee
coaxial cable breakdown votages
They are usually listed in manufacturers' data sheets. Expect values in the kV+ range.
breakdown voltage coaxial
Look at the attached file from Suhner catalog.
In any case consider we are using RG214 at 9 KV ( spark plug cable for special application ) without any problem since 1995.
Mandi
breakdown voltage of coaxial cable
Thanks a lot!
But why did I fail to find the attachment?
In fact, I find some data in Pozar's Microwave Engineering. However I fail to find what I want.
saryee
coax breakdown voltage
I get it.
hi .. i used rg58 for 5kV for years ;0)
What application do you use the cable in with such a high voltage?
high power tube power amps for short waves .. abt 5kW power out
regards
cancel
