BRAM CONTROL ISSUE
YoungEN
Newbie
Newbie level 1
Hi, there!
I recently trying to use BRAM as Simple DPRAM in Logic.
just send the 16bit data by register through AXI from Zynq, and received data store in BRAM and out through the my logic.
The thing is simulation is working properly... but in hardware isn't...
So I tried to write just register and out is properly worked...
How can I fix this errors.. Hope you guys give me a advise.. Thanks..
Here's my code below
module ad5764#(
parameter ADDR_WIDTH = 9,
parameter ADDR_DEPTH_DIV = 128,
parameter KHZ = 2500,
parameter default_val = 24'b00010100100000000000000,
parameter CONFIG = 5'b00010,
parameter MUX = 1,
parameter SEQ = 00,
parameter OTHER = 4'b1110
input wire [15:0] data_dac_in_1, // regin
input wire [15:0] data_dac_in_2,//reg in
input wire [15:0] data_dac_in_3, //reg in
input wire [15:0] data_dac_in_4, // reg in
input wire data_dac_en_1, //reg in
input wire data_dac_en_2, //reg in
input wire data_dac_en_3, //reg in
input wire data_dac_en_4, // regin
input wire sdo,
input wire rstn,
input wire clk,
input wire [12:0] read_addrs,
output wire sdi,
output wire sclk,
output wire sync_n,
output wire ldac_n,
output wire interrupt,
input wire clkb, //bram clk
output wire [31:0] data_out, //read to bram
//tast pins
output wire [31:0] sdi_c,
// output wire [2:0] st,
//output wire [5:0] det,
//output wire [6:0] addr_a, addr_b,
output wire en_c,
//output wire we_c,
//output wire [5:0] det_1,
//output wire sclk_c,
output wire [6:0] addr_i
reg [15:0] i_data_dac_1, i_data_dac_2, i_data_dac_3, i_data_dac_4;
reg [2:0] STATE = 3'b110, IDLE = 3'b111, DAC1 = 3'b000, DAC2 = 3'b001, DAC3 = 3'b010, DAC4 = 3'b011;
reg [ADDR_WIDTH:0] dac_go, dac_out;
reg [ADDR_WIDTH:0] i_addrs;
reg [5:0] data_reg, data_reg_1, data_reg_2, data_reg_3, data_reg_4;
reg [15:0] i_dac1, i_dac2, i_dac3, i_dac4;
reg cs_n = 1;
reg done = 0;
reg [5:0] data_cnt, data_cnt_1, data_cnt_2, data_cnt_3, data_cnt_4;
wire [31:0] data_in;
wire [15:0] sdi_o;
reg [0:23] sdi_out;
wire sck_in;
reg [0:23] sdi_in;
reg [4:0] out_cnt;
reg sck_o = 0;
reg [5:0] done_cnt = 0;
wire [5:0] in_bram_addrs;
reg [2:0] sck_cnt;
reg [2:0] out_time_cnt;
reg ldac_in, ldac_go;
reg [5:0] ldac_cnt;
reg [0:23] dac_store;
reg we_d, en_d;
reg data_shift;
reg i_en, i_we;
reg [6:0] a_addrs, b_addrs, c_addrs, d_addrs, h_addrs;
reg config_go;
wire [0:23] config_data;
reg CS_ST, STAY = 1'b0, RUN = 1'b1;
reg [31:0] data_dac;
reg [31:0] i_dac_data;
reg [7:0] addr_cnt;
reg [9:0] i_r_addrs;
reg i_interrupt;
reg o_interrupt;
reg [12:0] interrupt_cnt;
reg done_en;
reg [7:0] config_in;
reg en_sh1, en_sh2;
wire en_sh_o;
reg [15:0] i_data_dac_in_1;
reg [15:0] i_data_dac_in_2;
reg [15:0] i_data_dac_in_3;
reg [15:0] i_data_dac_in_4;
reg data_go_1, data_go_2, data_go_3, data_go_4;
reg en_done;
assign sdi_o = data_in[15:0];
assign sclk = sck_o;
assign sync_n = cs_n;
assign ldac_n = ldac_in;
assign interrupt = o_interrupt;
assign sdi = sdi_in;
assign sdi_c = i_dac_data;
assign en_sh_o = (en_sh1 && ~en_sh2);
// assign addr_i = i_r_addrs;
// assign sdi_c = sdi_out;
// assign st = STATE;
assign en_c = en_sh_o;
//assign we_c = i_we;
assign en_sh_o = (en_sh1 && ~en_sh2); //|| //(~en_sh1 && en_sh2));
always @(posedge sck_in or negedge rstn) begin
if(!rstn) begin
CS_ST <= RUN;
sck_cnt <= 0;
done <= 0;
end
else begin
case (CS_ST)
RUN : begin
done <= 0;
cs_n <= 0;
if(out_cnt == 23) begin
CS_ST <= STAY;
cs_n <= 1;
end
end
STAY : begin
done<=1;
cs_n <= 1;
sck_cnt <= sck_cnt + 1;
if (sck_cnt == 2) begin
CS_ST <= RUN;
sck_cnt <= 0;
done <= 1;
end
end
endcase
end
end
always @(posedge clk or negedge rstn) begin
if(!rstn) begin
i_en <= 0;
i_we <= 0;
i_addrs <= 0;
i_dac_data <= 0;
i_data_dac_in_1 <= 0;
i_data_dac_in_2 <= 0;
i_data_dac_in_3 <= 0;
i_data_dac_in_4 <= 0;
data_go_1 <= 0;
data_go_2 <= 0;
data_go_3 <= 0;
data_go_4 <= 0;
end
else begin
i_data_dac_in_1 <= data_dac_in_1;
i_data_dac_in_2 <= data_dac_in_2;
i_data_dac_in_3 <= data_dac_in_3;
i_data_dac_in_4 <= data_dac_in_4;
if(i_data_dac_in_1 != data_dac_in_1) begin
data_go_1 <= 1;
end
else if(i_data_dac_in_2 != data_dac_in_2) begin
data_go_2 <= 1;
end
else if(i_data_dac_in_3 != data_dac_in_3) begin
data_go_3 <= 1;
end
else if(i_data_dac_in_4 != data_dac_in_4) begin
data_go_4 <= 1;
end
else if(data_dac_en_1 && data_go_1) begin
i_dac_data <= {8'b0,CONFIG,3'b000,data_dac_in_1};
i_addrs <= a_addrs;
i_en <= 1;
if (en_done) begin
i_en <= 0;
data_go_1 <= 0;
end
end
else if(data_dac_en_2 && data_go_2) begin
// if(data_dac_en_2) begin
i_dac_data <= {8'b0,CONFIG,3'b001,data_dac_in_2};
i_we <= 1;
i_en <= 1;
i_addrs <= b_addrs + ADDR_DEPTH_DIV;
if (en_done) begin
i_en <= 0;
data_go_2 <= 0;
end
// end
end
else if(data_dac_en_3 && data_go_3) begin
//if(data_dac_en_3) begin
i_dac_data <= {8'b0,CONFIG,3'b010,data_dac_in_3};
i_we <= 1;
i_en <= 1;
i_addrs <= c_addrs + 2*ADDR_DEPTH_DIV;
if (en_done) begin
i_en <= 0;
data_go_3 <= 0;
end
end
else if(data_dac_en_4) begin
//if(data_dac_en_4) begin
i_dac_data <= {8'b0,CONFIG,3'b011,data_dac_in_4};
i_en <= ~i_en;
i_addrs <= d_addrs + 3*ADDR_DEPTH_DIV;
if (en_done) begin
i_en <= 0;
data_go_4 <= 0;
end
//end
end
end
end
if (!rstn) begin
en_sh1 <= 0;
en_sh2 <= 0;
en_done <= 0;
end
else begin
en_sh1 <= i_en;
en_sh2 <= en_sh1;
en_done <= 1;
if(!i_en) begin
en_done <= 0;
end
end
end
always @(negedge i_en or negedge rstn) begin
if (!rstn) begin
//i_addrs <= 0;
//h_addrs <= 0;
a_addrs <= 0;
b_addrs <= 0;
c_addrs <= 0;
d_addrs <= 0;
end
else begin
case (i_dac_data[18:16])
3'b000 : begin
a_addrs <= a_addrs +1;
end
3'b001 : begin
b_addrs <= b_addrs + 1;
end
3'b010 : begin
c_addrs <= c_addrs + 1;
end
3'b011 : begin
d_addrs <= d_addrs + 1;
end
endcase
end
end
dac_ram date_rx(
// Port A
.addra(i_addrs),
.clka(clk),
.dina(i_dac_data),
.ena(en_sh_o),
.wea(1'b1),
//Port B
.addrb(i_r_addrs),
.clkb(clk),
.doutb(data_in)
dac_ram data_o(
.addra(i_addrs),
.clka(clk),
.dina(i_dac_data),
.ena(en_sh_o),
.wea(1'b1),
//Port B
.addrb(read_addrs[10:0]),
.clkb(clkb),
.doutb(data_out)
endmodule
BRAM Trans
--- Updated ---
I couldn't write all the code by limit... but other side is working properly...
This is BRAM write side
