fjpompeo
Advanced Member level 1
tsz-i
I need the electronic schematic diagram of the Bosch TSZ-i electronic ignition module, the one that fires using a magnetic pick-up.
I bought an old car (VW 1984) that uses this ignition system with only one ignition coil and want to change to use two ignition coils so need to knwo how to get a square pulse to drive a flip-flop and then two IGBT each one fires a coil.
BTW My car is Ethanol (alchool) powered. That's the reason to add another ignition coil, so to get better spark and have no problems with humidity inside the distributor cap.
I bought a brand new car that uses this method but it comes with a whole multipoint electronic fuel injection system and run with two different combustible! Almost impossible and very expensive to adapt.
Regards,
Fernando
Regards,
Fernando
