philwinder
Member level 1
op amp input impedance
Hi again,
Further to my previous topic, I am looking to increase the input impedance of my opamp.
The first stumbling block is that I am using it in an inverting configuration (Charge Amplifier) and I do not beleive that I can bootstrap from the feedback because the inverted voltage applied back into the bias resistors would effectively decrease the input impedance. Is there any way to get around this? (Other than inverting again or using a non-inverting amp)
Also, I understand bootstrapping also increases the noise, but how does this compare to having a low input impedance to a high impedance source? I.e. Would the improved input impedance outweigh the increased noise?
Many thanks,
Phil Winder
Hi again,
Many thanks,
Phil Winder
