Boot Loader program and circuit for PIC16F877
nusliqiang
Junior Member level 2
For program the firmware in PIC16F877, we want to add the boot loader program in the firmware.
Anyone has any experience /suggestion about the firmware or the circuit ?
thanks
Search and Download the TINY bootloader 19.
Program the 16f877 with the bootloader code, using another programmer.
Connect tx,rx pin through Max232 to the serial port of the computer. The osc crystal frequency is 4MHz. Connect reset switch to mclr pin. Set the com port on the bootloader software. If 16f877 device is detected by the loading software, you are in business. Now you can upload any hex file you want without a separate programmer.
Enjoy.:D
Press the reset switch to go to bootloader mode
The best bootloader with free VB source code is Screamer V 1.6, I sware this is the best and the simplest I found. Ya, you first need simple programmer to load the bootloader and for that I am thankfull to FENG's MultiPIC programmer. good luck
