Bootloader:
Is not part of your application software. It is a piece of code to load your application code into the controller/processor. It is used only when you want to load a new software (version) onto the controller.
Example: a bootloader may communicate with the PC (using USB or UART) to load your application software from PC into the microcontroller's program memory. After that it can be executed.
Startup code:
Is a part of your application software. It is automatically generated by the compiler and added (at the programstart) to your application software. Usually you don't know, nor you have to take care about it. The startup code performs standard functions like data memory erase, stack pointer setup, standard periferal setup. This is performed each time immediately after reset/power_on and may take only some milliseconds. You won't recognize this. Then automatically your application software starts.
Klaus
