jayce3390
Full Member level 6
I have designed a boost converter using SMD components. I expected a flat output voltage response but some spikes occured (see attached picture) when the device is switching.
1. Do you know why?
2. Does it exist a solution to clamp?
Output : pink trace
Gate transistor waveform : green trace
Drain transistor waveform (diode anode) : blue trace
1. Do you know why?
Output : pink trace
