rragupathiraja
Newbie level 5
Hi
I am making a Boost converter for my inverter application..
Vin - 12V
Vout - 24V
Switching frequency - 300kHZ
Duty ratio - 50%
I am generating a PWM signal of 300kHz for switching the IRFP2907 MOSFET. The Driver used between MCU and FET is TC4424..
the inductor vale is 100Micro henry and cap is 10MicroF..
The problem is the load gets the applied voltage only.. No boosting is done in between the stages. If i am giving a 300kHz switching frequency for the mosfet and checking out the Pulse level its switching waveform is irregular.. IF i am using 10kHz the FET Vds is experiencing the 10kHz switching though there is n change in the output..
Help me in this regard
thanks
---------- Post added at 10:31 ---------- Previous post was at 10:30 ----------
iam uploading the schematic but its not getting uploaded..
Vin - 12V
Vout - 24V
Duty ratio - 50%
thanks
