Boiler room controller
gres
Full Member level 4
Full Member level 4
tmf said:
I would like to present project of universal boiler controller. Priority for me was to make us much universal controller us it is possible, that makes it useful piece of home apparatuses. Most important function is control at facilities of small boiler room ( boiler, solar panel, pumps, DW, floor heating). Functions of the controller are controlling by dedicated gallery ( Best one is RS485 but you can choose different). Control at boiler apparatuses through eBUS gallery ( Vaillant boilers) and GeniBus (electronic Grundfoss pumps). Computer role is just to have friendship interface, that let you make setups, which is difficult using simple interface of the controller. That way you can also make a backup. The boiler controller have interface that let to communicate with user – colorful graphic LCD + encoder for chose the setups. I wanted to make a controller that could fit in to the standard DIN rail. While need to use more IO ( for example more 230V tools) easy to extend chip set for simple expander boards – also for DIN rail.
Description:
- Brain of all construction is ATMega128 processor with 16 MHz
- RTC clock is based on PCF8563 chipset,
- 2x RS485 interface
- 1x RS232 interface (with level converter)
- 6x DAC (6 bit 0-10V)
- two extra slots for I2C memory ( FRAM and EEPROM)
- 8xADC (10BIT) – control at thermometer
- 1x1 wire
- 1x PWM output ( control at boiler)
- 8x 230V output
- LCD slot
- JTAG slot (debugging and programming)
- Power slot 10-24V-5V
P³ytka interfejsu LCD z pod³±czonym LCD.
P³yta g³ówna z na³o¿on± p³ytk± konwertera LCD.
More information at:
https://www.elektroda.pl/rtvforum/topic1477305.html
Description:
- 1x1 wire
- 8x 230V output
- LCD slot
Uniwersalny sterownik kot
Greetings to all from Spain
Super Boiler Controller Project! congrats
I have a vaillant TURBOmax VMW 28/362 and would like to ask if it would work something like
the other question is, does the protocol of vaillant EBUS is a rs485?
I need to read the boiler data using the software vrdialog
