Bluetooth simulation error: Mmi Ets library symbol load error
mohammadi458
thank you for help me
in document suite tooth wrote:"The version of the SuiteTooth model suite provided with this document will run with version 9.1.A of OPNET™ Modeler on a Windows operating system".
I add suitr tooth in opnet 10.5 and 14 when clic for runinig this error show:"Mmi Ets library symbol load error:
unable to find function (SuiteTooth_event_handler)
in shared module (C:\Documents and Settings\a\op_models\SuiteTooth\SuiteTooth_ets\suitetooth_event_handler.so)"
I need for simulation bluetooth i dont know work?
I came across the same problem "Mmi Ets library symbol load error"
Can you say something about how you solve this problem?
Thank you!
