Bluetooth interface circuit
quinceanyos
Junior Member level 3
Marawi City
bluetooth circuit
hi folks
i need to interface bluetooth to a microcontroller circuit..
please help me!
bluetooth circuits
hi quinceanyos,
if your microcontroler has a uart interface i would recomend you chack the NSC LMX9820A.
it is a grate Bluetooth modoule that has an UART interface after sanding it a few commend you can transfer the UART to transprant , then the link is just like a cable evrything you'll send to the uart will get rigth as is to the other side's uart.
+ it has an AAI(Advence Audio interface) an can interface with a PCM codec with no other componnet(glueless). and while having an audio link running you can stile talk with the modoule throu the uart interface.
more info is at:
h**p://www.national.com/ds.cgi/LM/LMX9820A.pdf
enjoy
iftah,
    quinceanyos
bluetooth dongle circuit
quinceanyos said:
hi folks
please help me!
You want interface a bluetooth dongle to a microcontroller?
You can PM me if you want to outsource the design.
    quinceanyos
bluetooth interface circuit
i have a circuit here. no need to outsource, i will email it to you for free..
circuit of bluetooth
atomu , can u please send that circuit to me too ?
thanks
circuit bluetooth
Can you send me the circuit by email, thanks!!!
bluetooth domgle ckt
atomu , I am interested on this topic, can you please send the circuit to me too ?
thanks
bluetooth interfacing circuit
atomu , can you please send the circuit to me for reference ?
thanks
bluetooth module circuit
hi..
atomu , can you please send the circuit to me?needed it for a project of my own.
thanks
bluetooth audio interface circuit
can i get the circuit too?
Thanks in advance
bluetooth circuit
hi atamo pls send me the circuit
thanks man
basic circuit for bluetooth
hi atamo can u help me i want the circuit too
thanks in advance
bluetooth circuit
hey hiii frnz,
I am very new to this community..in search of my project information, i came to know abt this site, which is very interesting..so i thought to post my problem here and hopping for the good results:D
my project concept is:
i want to send a contact number from my mobile using a bluetooth feature.....on the other side the microcontroller should receive that contact number with the help of bluetooth dongle connected to it.
but now i came to know dat it is not possible to connect a usb bluetooth dongle to a microcontroller for communication.
so, now my problem is, if it is not possible to connect a bluetooth USB dongle to a microcontroller for communication...then what can u suggest me..is there any alternative for this(i.e, is it possible to connect a bluetooth module to a microcontroller for communication??????)
pls do reply meeee....needed urgently!!:cry:
Thanks in advance...
bluetooth circuit
yes it is possible to connect embedded blue tooth modules with micro controllers. Check KC-21 module from kc wirefree
circiut for bluetooth device
hiiii,
thank u for ur response.. :)
yes i have seen the information about the kc-21...but i need a bluetooth module of version 2.0(i.e,which is the enhanced module that also supports the previous versions)
kc-11 bluetooth schematic
Roving networks. RN-41. 70 USD.. At Digikey
    V
bluetooth project schematic
hi;
the topic is so interesting can you e-mail the circuit for me too.
tnx:D
pulse reading circuit of bluetooth
hi atomu,
can u pls send me the circuit too??i need it for my project work.
thnx.
