[SOLVED] Blink Code ATmega2560 not working in Proteus
chandlerbing65nm
Member level 5
Member level 5
I am running a simple blink program in an ATmega2560 with external 8MHz crystal. When I run it in Proteus, the LEDs do not blink. Refer to my files below.
This is the simple blink code. I just add prescaler bits to verify its functionality.
void setup() {
      noInterrupts();
      CLKPR = 0x80;                           /*Enabling the clock prescaler function*/
      CLKPR = 0x00;                           /*Setting the prescaler to div by 1*/
      interrupts();
      pinMode(13, OUTPUT);
    void loop() {
      digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(500);                       // wait for a second
      digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
I correctly choose the ATmega2560 with external 8MHz.
And this is my circuit in Proteus: (Removing the VDD in reset, AVCC, AREF doesn't help.)
And I set the fuse bits to work with external crystal:
I don't know where I went wrong. Please help.
--- Updated ---
Problem already solved. Pinning in Arduino Mega does not follow actual pinning in ATmega2560. I found the pin map here: Arduino Mega - ATMega2560 Pin Mapping
