Blind channel Equalization
senaydud
Full Member level 1
Does anybody know anything about which techniques they use for blind channel equalization?
any idea? please respond if you know anything
They use Adaptive filtering aniway
I think they dont need adaptive filtering all the times, they sometimes equalize the channel making use of the higher order statistics of the received signal without the need of adaptive calculation.
maybe, You can try to find some information about the CMA algorithm (Constant Module Adaptive)
    senaydud
Equalisation is the technique of removing the effect of dispersive channel that causes ISI. The very heart of the problem of ISI is that the current symbol is effected by symbols that are transmitted before and symbols that that are to be transmitted next.There are many to EQUALISE
1)use pilot sequence to estimate channel
2)use algorithms like LMS,NLMS etc. if desired signal is known.
3)use blind equalisation if desired signal not known.
Blind equalisation is done using
1)Higher order statistics
2)constant modulus algorithm etc.........
