blind, burried, micro via???
bijug007
Junior Member level 3
burried via
Whats the differnce between blind burried and micro via?
Thanks
burried vias
Blind and buried vias .. laser drilled microvias:
Regards,
IanP
micro blind via
Blind via: It's from one of the surface to any of inner layer.
burried Via: It's via that is between inner layers. burried via is not accessable from top or bottom laye.
Microvia: These are the vias with narrow drill hole. usually these vias are directly present in component pads.
via, microvia, blind and buried vias
Micro vias can be Via-In-Pad as suggested, however not required. Microvias also require a specific hole to thickness ratio - which is why you will not have a micro-via go more than from the TOP layer to layer 1 or 2.
