T
treez
If a three phase BLDC and its voltage source inverter is pumping water and spinning at 8000rpm, , at maximum duty cycle, with a 34V DC link, and taking 20 Amps, then what happens if the water suddenly goes and the pump is operating dry?
Does the pump suddenly speed up?
The BLDC Inverter operates always at maximum duty cycle, and the motor current is limited by a current source SMPS upstream of the inverter........presumably, the current source would need to suddenly reduce its current if the water ran dry?
