son0102
Newbie
- Joined
- Dec 30, 2024
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 27
I have a sensorless bldc motor. Motor: 310VDC-380VDC, 1.2A, 150W, 1100 rpm, 10 pole, 12 slot.
I'm trying to control the speed. I used the circuit and code on the internet.
this's diagram:
this's code:
I tried 12VDC motor, it's no problem.
What is the problem?
this's diagram:
this's code:
But just started, the mosfet is broken. I don't have an oscilloscope to check./* Sensorless brushless DC motor control with Arduino UNO and IR2101 (Arduino DIY ESC).
* BLDC motor speed is controlled with a potentiometer connected to A0.
* This is a free software with NO WARRANTY.
* http://simple-circuit.com/
#define PWM_MAX_DUTY 255
#define PWM_MIN_DUTY 10
#define PWM_START_DUTY 40
byte bldc_step = 0, motor_speed, pin_state;
void setup()
DDRD |= 0xE0; // configure pins 5, 6 and 7 as outputs
PORTD = 0x00;
DDRB |= 0x0E; // configure pins 9, 10 and 11 as outputs
PORTB = 0x31;
// Timer1 module setting: set clock source to clkI/O / 1
TCCR1A = 0;
TCCR1B = 0x02;
// Timer2 module setting: set clock source to clkI/O / 1
TCCR2A = 0;
TCCR2B = 0x02;
// ADC module configuration
ADMUX = 0x60; // configure ADC module and select channel 0
ADCSRA = 0x84; // enable ADC module with 16 division factor (ADC clock = 1MHz)
PCICR = EIMSK = 0; // disable all external interrupts
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
// pin change interrupt 2 (PCINT2) ISR
ISR (PCINT2_vect)
if( (PIND & PCMSK2) != pin_state )
return;
// BEMF debounce
for(byte i = 0; i < 20; i++)
if(bldc_step & 1){
if(PIND & PCMSK2) i -= 1;
else {
if(!(PIND & PCMSK2)) i -= 1;
bldc_move();
bldc_step++;
bldc_step %= 6;
// BLDC motor commutation function
void bldc_move()
switch(bldc_step)
case 0:
AH_BL();
BEMF_C_FALLING();
break;
case 1:
AH_CL();
BEMF_B_RISING();
break;
case 2:
BH_CL();
BEMF_A_FALLING();
break;
case 3:
BH_AL();
BEMF_C_RISING();
break;
case 4:
CH_AL();
BEMF_B_FALLING();
break;
case 5:
CH_BL();
BEMF_A_RISING();
void loop()
SET_PWM_DUTY(PWM_START_DUTY); // setup starting PWM with duty cycle = PWM_START_DUTY
int i = 5000;
// motor start
while(i > 100)
delayMicroseconds(i);
bldc_move();
bldc_step++;
bldc_step %= 6;
i = i - 20;
motor_speed = PWM_START_DUTY;
PCICR = 4; // enable pin change interrupt for pins PCINT23..16 (Arduino 0 to 7)
while(1)
ADCSRA |= 1 << ADSC; // start conversion
while(ADCSRA & 0x40); // wait for conversion complete
motor_speed = ADCH; // read ADC data (8 bits only)
if(motor_speed < PWM_MIN_DUTY)
motor_speed = PWM_MIN_DUTY;
SET_PWM_DUTY(motor_speed);
void BEMF_A_RISING()
PCMSK2 = 0x04; // enable Arduino pin 2 (PCINT18) interrupt, others are disabled
pin_state = 0x04;
void BEMF_A_FALLING()
pin_state = 0;
void BEMF_B_RISING()
PCMSK2 = 0x08; // enable Arduino pin 3 (PCINT19) interrupt, others are disabled
pin_state = 0x08;
void BEMF_B_FALLING()
pin_state = 0;
void BEMF_C_RISING()
PCMSK2 = 0x10; // enable Arduino pin 4 (PCINT20) interrupt, others are disabled
pin_state = 0x10;
void BEMF_C_FALLING()
pin_state = 0;
void AH_BL()
PORTD &= ~0xA0;
PORTD |= 0x40;
TCCR1A = 0; // turn pin 11 (OC2A) PWM ON (pin 9 & pin 10 OFF)
TCCR2A = 0x81; //
void AH_CL()
PORTD &= ~0xC0;
PORTD |= 0x20;
TCCR2A = 0x81; //
void BH_CL()
PORTD &= ~0xC0;
PORTD |= 0x20;
TCCR2A = 0; // turn pin 10 (OC1B) PWM ON (pin 9 & pin 11 OFF)
TCCR1A = 0x21; //
void BH_AL()
PORTD &= ~0x60;
PORTD |= 0x80;
TCCR1A = 0x21; //
void CH_AL()
PORTD &= ~0x60;
PORTD |= 0x80;
TCCR2A = 0; // turn pin 9 (OC1A) PWM ON (pin 10 & pin 11 OFF)
TCCR1A = 0x81; //
void CH_BL()
PORTD &= ~0xA0;
PORTD |= 0x40;
TCCR1A = 0x81; //
void SET_PWM_DUTY(byte duty)
OCR1A = duty; // set pin 9 PWM duty cycle
OCR1B = duty; // set pin 10 PWM duty cycle
OCR2A = duty; // set pin 11 PWM duty cycle
