yefj
Advanced Member level 5
Hello, i have a circuit shown bellow which is taken from an attached presentation.
Ifi understand it correctly i need to supply DC current for 2u FM coil.
the presentation slide bellow misses info.
i know that R3 R7 for BC807-40 PNP above is for biasing.
I have few questions:
1.At what state do you think the PNP is in?
the table bellow shows the PNP states and i am not sure to what state should i bias the PNP?
2. we have negative feedback feed to the opamp,i can see that the feedback could help with keeping in proper place the PNP biasing.
If i am correct is there a way i could analize how exactly this feedback meachanism works?
Thanks.
UPDATE:
Suppose at some point the VFM voltage rises from V0 to V0+0.01V So V_minus of the opamp rises too,So what causes the voltage on VFM to return to V0?
Thanks.
Thanks.
--- Updated ---
UPDATE:
Thanks.
