BJT RthJA value: Conditions of measurement?
eem2am
Banned
Hello
For BC817-40 , on first page of datasheet there is a RthJA value given of 357C/W
It is not clear whether or not this is for the case of mounting on PCB of are 40mm * 40mm.
Do you know what is the likely RthJA of BC817-40, when connected to no more copper than 0.8mm tracks coming to the B,C, & E pins?
BC817-40 Datasheet
http://www.datasheetcatalog.org/datasheet/fairchild/BC817-40.pdf
It will be 375C/W when mounted to 40x40mm of PCB. The asterisk is on the column, implying the not applies to all values in the column.
Philips quote 500C/W with "standard footprint" so that would be a reasonable guide.
Keith.
