Dear sir/madam, which simulation software did you use here? I guess the name is 'Simplis simulator'. I never heard of it before. Is it something equivalent to the P-spice? Thanks in advance.B does seem OK as Stewart states.
Circuit C does achieve very high duty cycle, based on delays between the coupled
NPN and PNP pair, but thats a very poor design due to device to device variation
and other T and V effects.
Regards, Dana.
Thanks thats exactly what i meant......A npn needs a diode placed with anode to base and cathode to collector....to sweep out charge carriers...in C, this diode is there, but is the wrong way round.....(its the diode in the PNP, ie the base-emitter diode).....so there will be storage time effects which will delay the switching of the BJTs.Circuit C does achieve very high duty cycle, based on delays between the coupled
