McShamrock
Member level 1
- Joined
- Oct 29, 2006
- Messages
- 39
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- ITALY - Sardinia
- Activity points
- 1,673
bjt switch circuit
I have an IC device which provides a pin in order to decide if turn the device ON or OFF. If the pin is HIGH, the device is OFF, otherwise is ON. Actually, the device pin is internally pulled-up at Vcc (equal to 3.8V) via a resistor R2 (equal to 47K) and if you would like to turn ON the device you have only to connect that pin to ground. I would like to remote control the turning ON/OFF, thus a BJT switch is needed.
Assume to not consider R3 (R3 = inf) in the figure below.
To decide how large should be R1, I made in this way:
The current which passes in the transistor from C to E (Ice) is about Vcc/R2 since Vce is about zero when the BJT is closed. By reading from the BJT datasheet the range of hfe (hybrid parameter), I considered the hfe minimum in order to estimate the maximum base current (Ib) needed to let BJT working at the desired Ice. In practice, to be further sure, I considered an high value for Ib: two or three times that calculated. Then, R1 is given by Vin/Ib.
Now, why does the IC device HW guide suggest me to use a BJT switch putting another resistor (R3) between C and E as weel? In a practical example, the guide says both R1 and R3 are equal to 47K in case of Vin=3 to 5 Volt. Let consider hfe = 200 to 450 and Vbe = 0.77 Volt.
Thx
N.
Thx
N.
