[SOLVED] bit-select or part-select is not allowed in a assign statement for non-net
stackprogramer
Full Member level 3
Full Member level 3
How can I initialize a reg array in Verilog...Any offer?
reg m_shift_value[3:0];
    initial begin
          //Initial registers
          assign {m_shift_value[3],m_shift_value[2],m_shift_value[1],m_shift_value[0]} = {0, 32, 64, 96};
      end
Why are you using assign statement in an initial block where you should use = ?
How are assigning decimal literals to a bit array that can only take 0 and 1 values?
Thanks very much so I concluded that I should use this method for initializing the reg array...
I should use assign for wires...
initial
          begin
              reg m=0;
            for (k = 0; k < 4 - 1; k = k + 1)
              begin
                  m_shift_value[k] = m;
                  m=m+32;
              end
          end
