bit flipping algorithm
bunty_22
Newbie level 5
Newbie level 5
hello
i need verilog hdl code for bitflipping algorithm
plzz help me out
IBM invented the HIPO method of specs.
Hierarchical
Inputs
Processes
Outputs
Input =
Process = flip when ....
Output =
Not is a miscellaneous or logical operator .
For VHDL NOT is an inversion operation, but in Verilog, which is what the OP wants, the logical operation is ! and the bitwise operator is ~.
I must say that any decent (well even that bad ones) tutorial will have that as one of the first things that is shown (Verilog operators).
the parity check matrix is 8*16;
well the input to encoder is 00001100..after encoding it is 1100100000001100;
the noise is 8 bit i.e 00000001
so these are d inputs
jus gimme an idea how to write d code
thanks
genvar i;
generate
for( i=0; i<length; i=i+1 )
begin :
if somevariable_bitposition
assign working = not working;
else
assign working = working;
endif
end
endgenerate
genvar i;
generate
begin :
else
endif
end
endgenerate
What is this not doing in the code not is a Verilog keyword for a NOT gate and has to be instantiated. Then you are using endif which is a VHDL keyword? Hmm, it can't be VHDL code as there is the assign statement which is a Verilog keyword and there is a genvar too!
Do you know either language or is this pseudo code where you're mixing languages to confuse the OP so they go away ;-).
The rest of the post is missing.
There was a paragraph above the code section that included ' dis is d PSEUDO CODE' ,.
But it should be clear that it is 'PSEUDO'
'if somevariable_bitposition',
Obviously neither verilog/VHDL
Yep, there is a mixture, I had two projects open , VHDL/ Vlog , debugging an FPGA SATA interface with a broken JTag Cable which requires a finger, plus I was dealing with a SF-Express and an aliexpress seller on chat..
The rest of my post is obviously included in the cut & paste to Ali-express……
Good thing then that it doesn't make too much of a difference. It's always a surprise what you are going to get this time, no matter what you specify to the seller. ;-)
Yes,
That's why I sit on these guys…..
In reality I know FS-express scans at collection within 10 minutes, they show scanning yesterday (13th), 4 days AFTER seller stated them as shipped.(It's 1-2 day delivery to H.K)
I need these silicon sheets to get a bigger heatsink on the FPGA, it's starting to smell, short some place……
