bistable latch operation using 2 coin cell
rajaram04
Advanced Member level 3
earth
Hello sir
i am using 2 coin cell 3 volts of each to drive this transistorized bistable latch
coin cell i am using is this one
but unable to even switch it on :-x:x:roll::cry:
means exactly what?
You might be able to find unsuitable resistor values that eliminate bistable behaviour.
no no circuit is completly working with rechargable cells , common 9v cell & external adapters
but with coin cell it is not working , infact the circuit is not even going to switch on :shock:
Then it's most likely another case of unsuitable resistor values (resistance too low).
k so how to overcome that ? i mean how can i choose values ? what should i connect there ?
These tiny cells have a tiny amp-hour rating.
The resistors in this simulation are high enough so that current draw is always under 1 mA (with a 6V supply).
It should work with hardware.
oh i see lots of theories are there for me still have to apply in practice
well sir i saw mostly designs with green baground & green grey circuit diagrams & waveform , which soft you are using ?
I too want to design such things for analysis
This is Falstad's interactive animated simulator. (A free download at: www.falstad.com/circuit)
Click the link below to go to his website, load my simulation, and run it on your computer.
https://tinyurl.com/d2e56ov
You can watch the circuit change state. Just click on the switches.
Edit values by right-clicking on a component, and select Edit.
