djnik1362
Full Member level 2
Hi
I need to design a custom Bipolar Signal Driver.
This signal transmitted with two lines . One line have signal with +15 V and -15 V and the
other line connected to ground . On the other side there is a differential receiver which when
one line be greater than return (GND) line then produce logic 1 and when the line be negative
then produce logic 0 .
How can i produce such a signal ?
Levels are important . (+-15 V).
Thanks for your support.
