Biometric Fingerprint module (ADST11SD300&310)
callmepeejay
Newbie level 1
Newbie level 1
Hello guys, i saw a post about a biometric fingerprint scanner exactly as mine. I still cant figure it out. unfortunately, the thread was closed. I badly need help, anyone??
Hello Brad! I was talking about the biometric fingerprint with the write template issue. I wish I could get his other codes as a basis.
I want to at least know how the Enroll Program is. The Biometric SCanner Module Im using is (ADST11SD300&310). this is the Manual. https://docs.google.com/file/d/0BxdLxDCD6HidaEE1djVZTENSR2M/edit
Basically, I send a 24 byte Command Data then the Module sends a 24 byte Response Data.
. help?
