baileychic
Advanced Member level 3
This is my code to print number in binary format but it is not printing properly. What is the problem ?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 #include <built_in.h> #define UINT16_TO_BINARY_PATTERN_1 "<%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c>" #define UINT16_TO_BINARY_PATTERN_2 "<%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c>\r\n" #define UINT16_TO_BINARY(uint16_t) \ (uint16_t & 0x8000 ? '1' : '0'), \ (uint16_t & 0x4000 ? '1' : '0'), \ (uint16_t & 0x2000 ? '1' : '0'), \ (uint16_t & 0x1000 ? '1' : '0'), \ (uint16_t & 0x0800 ? '1' : '0'), \ (uint16_t & 0x0400 ? '1' : '0'), \ (uint16_t & 0x0200 ? '1' : '0'), \ (uint16_t & 0x0100 ? '1' : '0'), \ (uint16_t & 0x0080 ? '1' : '0'), \ (uint16_t & 0x0040 ? '1' : '0'), \ (uint16_t & 0x0020 ? '1' : '0'), \ (uint16_t & 0x0010 ? '1' : '0'), \ (uint16_t & 0x0008 ? '1' : '0'), \ (uint16_t & 0x0004 ? '1' : '0'), \ (uint16_t & 0x0002 ? '1' : '0'), \ (uint16_t & 0x0001 ? '1' : '0') char txt[128]; unsigned int i = 0; unsigned int my_16_bit_number = 0; void main() { CM1CON0 = 0x00; CM2CON0 = 0x00; SLRCON = 0x00; ANSELA = 0x00; ANSELB = 0x00; ANSELC = 0x00; ANSELD = 0x00; ANSELE = 0x00; TRISA = 0x00; TRISB = 0x00; TRISC = 0x80; TRISD = 0x00; TRISE = 0x00; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; PORTD = 0x00; PORTE = 0x00; LATA = 0x00; LATB = 0x00; LATC = 0x00; LATD = 0x00; LATE = 0x00; UART1_Init(9600); Delay_ms(100); UART1_Write_Text("16-bit number rotated number\r"); UART1_Write_Text("-------------------------------\r"); while(1) { for(i = 0; i < 65536; i++) { my_16_bit_number = i; sprintf(txt, UINT16_TO_BINARY_PATTERN_1, UINT16_TO_BINARY(i)); UART1_Write_Text(txt); my_16_bit_number = (my_16_bit_number << 1) | (my_16_bit_number >> 15); sprintf(txt, UINT16_TO_BINARY_PATTERN_2, UINT16_TO_BINARY(my_16_bit_number)); UART1_Write_Text(txt); Delay_ms(1500); } } }
