Bicycle Dynamo Lights control.
Prashantakerkar
Member level 4
Member level 4
Is it possible to control the different lights colors generated by the Bicycle dynamo ?.
Thanks & Regards,
Prashant S Akerkar
how can a bicyle dynamo generate colors?
Again a very vage question.
Klaus
Thanks.
I mean the different Led colors in the bicycle dynamo. Can it be controlled?.
Thanks & Regards,
Prashant S Akerkar
My bicycle dynamo has no LEDs at all. The front light uses a white LED and the rear light red LEDs. Which light colors do you want to control?
Thanks.
I mean can the Bicycle Dynamo be designed and constructed having different Led colors?.
Thanks & Regards,
Prashant S Akerkar
Please be more precise. As already mentioned, the dynamo doesn't involve LEDs or any kind of control. It's just an AC generator. The on-off switch, rectifier, current regulator are usually are usually inside the front light.
You can think about a front light using colored LEDs, consider however that the design must comply with official regulations. I guess colored front lights, or back light colors other than red won't be permitted.
Thank you.
Exactly, I want different LEDs colors viz Green,Blue, Yellow,Orange,White and not only red driven by the Dynamo.
Can this be achieved?.
Thanks & Regards,
Prashant S Akerkar
Using my vast technical expertise on the subject:
Prashantakerkar: You need a green dynamo to generate the green electricity for the green LED, A blue dynamo to generate blue electricity for the blue LED, a yellow dynamo to generate yellow electricity for the yellow LED and a red dynamo to generate red electricity for the red LED. The white one needs lots of dynamos so you can mix the colors to obtain white.
Or did I miss something?
Brian.
Reactions: KlausST
    KlausST
