Under inversion from Willy sansen's notes, you will have three inversion region: weak inversion, strong inversion and velocity saturation region and those depends on how hard you bias the Vgs.
IDS in strong inversion resembles (Vgs-Vt)^2 law, while weak inversion is an exponential relationship and velocity saturation varies linearly with Vgs, so your question should vary a lot in weak inversion, which is normal.
Small signal model does not depend on region, all you need is to add gm, rds, vgs, etc..
