awan
- Joined
- Jun 11, 2004
- Messages
- 106
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Los Angeles
- Activity points
- 815
Biasing of OPAMP
Hi;
I have a question in biasing an OPAMP. I only have +3volts supply on my circuit.
The OPAMP i am using requires +3volts and -3volts. So, do i need to generate -3volts supply for biasing? If i use 0volts instead of -3volts then my simulation is incorrect.
What is the bestway to fix this problem. Is there a fix without needing to generate the -3volts?
Thanks
Hi;
Thanks
