tshankar501
Member level 2
- Joined
- Dec 26, 2004
- Messages
- 45
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Arizona, US
- Activity points
- 362
Why is "Bias Resistor Transistor" is used? Please google the word and you can see lot of "Bias resistor transistors" are being sold by different companies?
Please tell what is the advantage of this "Bias resistor transistor" holds when compared to the ordinary BJT? In what way is the resistor between base and emitter helps? I find that in all the application notes listed by different companies, replacing the "Bias Resistor Transistor" with this ordianry BJT works fine...
Also in all the datasheets, it is explicitly said that these "Bias resistor Transistors" are used for digital signals. For digital operation, we dont need to bias the input at all right?
