- Joined
- Jan 22, 2008
- Messages
- 53,225
- Helped
- 14,794
- Reputation
- 29,875
- Reaction score
- 14,318
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 301,545
Achievable output impedance and maximum output voltage are different limitations of a real current source.
As already stated in several posts, the output voltage of an active current source will be always limited by the supply voltage. High voltage OPs or discrete transistor amplifier circuits can be used to increase the output voltage of your current source. In some cases, an output transformer may be a solution for a pure AC current source.
The howland current source's output impedance is particularly restricted by resistor matching errors, generally the OP gain restricts the achievable output impedance of active current sources and the gain-bandwitdh product the output impedance at high frequencies.
If you calculate the output impedance, you'll notice that the shunt resistor value is also a factor of output impedance. Implementing a large current ratio with respective low shunt resistance gives a lower output impedance than a smaller range with respective higher shunt value.
So the first point would be to derive a realistic specification.ö
