pmi
Newbie
I am using a MCP3008 8 channel ADC to capture some different voltage levels on a board I am making that interfaces to a Raspberry Pi through the SPI bus. The clock speed is ~2.4 MHz. Since the ADC inputs need low impedance inputs, I thought I would use a TLV2464 (8 op amps) configured as unity gain buffers for each input to the ADC. The board has three DC power systems - 3.3V, 5V, and 12V, and the 12V system uses a MOSFET to deliver 2-4 A to a load every few minutes for about 1 second. The voltages under measurement are changing during the time the MOSFET delivers the 2-4 A.
I was wondering how I should filter the inputs of the 8 op-amps in the TLV2464 chip. Maybe just a 1 nF cap to ground?
Thanks!
Thanks!
