best programming language
bader
Member level 1
Member level 1
what is the best programming language for interfacing???????
This really depends on what your goals are. What
operating system, which port (serial, parallel, USB,
PCI, etc). Also, what language do you program in?
Easiest for parallel/serial port interfacing would
probably be using QBASIC under DOS. If using
Windows, easiest would probably be VB (MSComm
control for serial, Inpout32.dll for parallel port if
using WinXP).
This topic comes up over and over again, so doing
a search of the board should give you lots to read.
Nick
All windows drivers are written in C, so all driver access are basically through system dlls. So the ideal language, and the most efficient one, should be in C.
I will suggest using C because all device interfacing is done best using it.It is fast.
Use c... a lot of resources available.. fast & compact
c language is quite easy to use when doing interfacing with parallel port
you can also try visual basic
if you are using c pls note dat the speed of parallel port is slower than the speed of the compiler so insert proper delays between the statements
c is the best , but vb is easy to start too.
i'm used Visual Basic , easy and powerfull
depends on your rating standards : )
