ivan27807
Junior Member level 2
- Joined
- Dec 19, 2011
- Messages
- 23
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,283
- Location
- United Kingdom
- Activity points
- 1,461
Hi Guys,
I have been wondering what's the best practice in setting a package keepout in the pcb area in Altium. I am working on an electronics company which most of the products are house on a mechanical metalwork. I have previous experience in cadence allegro and I was using package_keepout_top and package_keepout_bottom to set height restrictions on certain areas of the board. However, in Altium I can't find the certain layer to do that and I also don't know how to create a rule to define height restrictions on specific areas of the board.
For example I have a 85mm by 35mm board, the upper half of the secondary side (bottom side) can accommodate component heights only up to 7mm while on the lower half of the secondary side (bottom side) can accommodate height up to 14mm.
I have tried using the Placement==>Height in Design Rules however it was not able to call the error.
If further details are needed to come up with a good picture of the situation, kindly let me know.
Thank you in advance.
