Best method of cleaning corrosion
Sputnik
Full Member level 3
Full Member level 3
South Africa
What is the best method and technique for cleaning corrosion of circuit boards, etc.
Thanks
Sputnik :idea:
You can clean the corroded PCB with the Shell X55 Solvent (you will not be able to kill corrosion 100%), dry it, and apply Circuit Board Lacquer for protection.
read this article its described exactly what u need:
