carlmbecker
Newbie level 6
Hi all.
What would be the best measurement method for the following impedance measurement :-
I am injecting a signal of a few Hz (10Hz) up to a few MHz (3MHz) in increments of a few Hz. I then measure the injected signal and the returned signal which varies in amplitude depending on the frequency (device under test resembles a complex impedance with LRC components). This is performed in steps (1) first inject 10Hz - do measurements on both signals. Process the data then (2) increment signal .....
Time is not an issue.
I would ultimately like phase and magnitude (info) between the injected and returned signal.
I could use various ways of extracting this info but looking for advice from people more familiar with DSP techniques. (FFT, FIR only etc.....)
Thanks in advance
Thanks in advance
