best language to programme windowsxp
mexx
Member level 2
Member level 2
can anyone tell me which is the best language to program windows xp?
is it vb.........can we do anything with matlab....err i mean can we access windows memory in matlab environment/////////////?????????
hi can anyone suggest a tutorial or e-book which can give some basic or in depth knowledge for programming windows xp...
regards
mexx
For "normal" operation software development with beautiful GUI, I recommend VB. However, for "high load" software development with huge memory consumption, I recommend VC++.
Visual C++ for sure and then ready for questions at MSDN :)
No doubt C++.
I think you should determine your application. I can recommend the following cases:
1. If you want to have a good GUI and can make your front-end easily, I recommend VB or Borland Builder. The Borlan Builder is very good to develope a software, but it has a drawback. The biggest problem of it is related to the lack of compatibility with Windows, because of different corporations developed them.
2. If you want to develop an application as a professional programmer, you can use VC++. The biggest advantage of it is related to compatibility with Windows. Because both of them have developed by Microsoft Co.
I have a compiled HTML help file entitled "Programming Windows with MFC". I it is not in the E-book upload of Electroda, i can put it there to access all people.
Regards,
KH
Delphi or Borland Builder. Such a cool tool.
Point and click, drag and drop.
A pleasure to use.
hi,
if u want to program any windows os, then vc++ is best and will hold in the long run,
if u want to learn windows programming in depth try "Windows Programming by charles petzold", this the first book any good windows programmer would prefer to read.
