best IDE for Xindows under linux
sa007jbond
Member level 1
Member level 1
Hi all,
I locking for good/best GCC IDE for Xindows under linux, similar Visual or borland C/CPP.
Any sugestion is well come.
Thanx
vi is the best. Vim takes second place, if you are looking for a gui. Don't believe anyone that tells you emacs/xemacs kicks butt.
Dont believe him...
There's ha fight over there, you can se it here:
First : w_w_w.itworld.com/AppDev/575/swol-1095-software/
There are lots of em, depends on what are u pretending to do, the most experienced users prefer emacs, vi, even pico...
But asuming that u are not, or just looking for another program. You should see...at leats give a chance to:
kdevelop. I know you have seen this.
qtdevelop. This guy looks a lot vbasic or the other visual thing on wintendo.
glade: I know you have seen this too.
There are others, but I know you probably end using emacs, pico(comes in pine), or maybe but less probaly vi.
Hi
User from GNU VIDE
here it is:
1. h**p://www.objectcentral.com/vide.htm
* -> t
tnx
I use slickedit for linux. Also it can be used for remote debuging with gdb.
