Tuppe
Member level 2
Hello,
I'd like to ask just a quick sanity check question about my approach in my design.
I'd need to know what is the most reasonable solution to switching high loads, such as 12V solenoids/relays within low-power(e.g. battery powered) system?
I'm planning to use 3.3V MCU(to save idle consumption), for which the load is driven with a boost converter. Is this unreasonable solution for proper electronics design?
Should I run the whole system under 12V and constantly buck the voltage for the MCU?
For some reason I couldn't be able to find 3-5V water valve.
In my application the load is going to be switched under a minute at a time and 5-10 times per day, but I'd like to know that when professional opinion about in which case it's wise to use a boost converter... For example, if the load is switched 50% of the time, is it wiser to use 12V system voltage instead or some other solution?
Thanks for reading!
Thanks for reading!
