[SOLVED] Best and easy software for PCB routing schematic layouts?
tauseefrehman
Junior Member level 1
Hi evry1
I need to know the best software for pcb layouts. I have used Proteus and understand it but its not that much good for PCB layouts. The reason i guess is that its routing paths are very narrow. Than after echting it on board it becomes more narrow.
Thanks in Advance.
If your tracks are coming out too thin on Proteus then you need to learn how to use it correctly. That will apply to any software package. ALL PCB layout packages allow you to change the track width.
Keith
