BenQ's M22 modem issues with PIN command
snicolasss
Newbie level 3
Newbie level 3
:| Hi!
I'm using a BenQ's M22 modem. When I send a AT+CPIN it connects without a problem, BUT some time after that (in a matter of days) the modem responds at this command with an ERROR. This fixed by giving to the modem a bigger delay between the last command (ATEO) and the AT+CPIN command, but i'd like to know why's the modem doing this or if is any way to know when should I send the PIN command.
Thanks a lot.
Re: M22 PIN issue
depends on what chipset it uses
makers usualy make there modem cards with several vendors chipsets
so they dont keep there eggs in one basket
try at&t command and paste the reply up to view
the chip maybe even has a faulty firmware
try looking for a firmware update for it
this maybe is a known issue
:D
