Lucast85
Member level 3
Hi everyone,
I've a doubt about the benefits of the air gap to increase the creepage distance between two conductive parts of a component.
I could explain my doubt by using an example with an ethernet transformer.
As highligted in the previous image, I suspect it is possible to consider 2 different creepage distances:
My observations are the following:
Thanks,
- In blue the creepage along the componet's surface itself (in the back side of the transformer) that is the minimum distance between the pins (conductive parte to be isolated) of the componets;
- In red the creepage along the PCB's surface that is the distance between the pads on the PCB;
- With the air-gap (PCB slot) I can increase the creepage distance along the PCB surface (red line in the previous image), but the creepage along the component's pins (blue line) remains inalterated, thus:
- If the considered pollution degree is 1, then the air gap is almost unuseful because all the material group (PCB material e.g. FR4 and transformer material) are grouped into the same column. This means that the min. creepage distances along the PCB and along the component's surface (two different materials) must be the same. In this case, the pins spacing is critical.
- If the considered pollution degree is 2 or 3, then the air gap is useful because the crepage distance to be considered could be splitted in two: the creepage along the surface of the component that is frequently better than material group III and the creepage along the PCB that is usually material group III. In this case, along the PCB, I can reach the creepage prescribed by the normative (usually higher than the creepage distance prescrived along the component surface) by using the slot.
- If the considered pollution degree is 2 or 3, and the material group of the PCB and the material group of the component are the same, then the situation is the same of the point 1.
Thanks,
